Test LB+PPO0215
PPC LB+PPO0215
"PodWW Rfe DpDatadW Rfe DpDatadW PosWW PosWR PosRR DpDatadW"
Cycle=Rfe DpDatadW Rfe DpDatadW PosWW PosWR PosRR DpDatadW PodWW
Relax=
Safe=Rfe PosWW PosWR PosRR Pod*W DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodWW Rfe DpDatadW Rfe DpDatadW PosWW PosWR PosRR DpDatadW
0:r2=a; 0:r4=x;
1:r2=x; 1:r4=y; 1:r9=z; 1:r11=a;
 P0           | P1             ;
 lwz r1,0(r2) | lwz r1,0(r2)   ;
 xor r3,r1,r1 | xor r3,r1,r1   ;
 addi r3,r3,1 | addi r3,r3,1   ;
 stw r3,0(r4) | stw r3,0(r4)   ;
              | li r5,2        ;
              | stw r5,0(r4)   ;
              | lwz r6,0(r4)   ;
              | lwz r7,0(r4)   ;
              | xor r8,r7,r7   ;
              | addi r8,r8,1   ;
              | stw r8,0(r9)   ;
              | li r10,1       ;
              | stw r10,0(r11) ;
Observed
    0:r1=1; 1:r1=1; y=2;
