PPC LB+PPO0196 "PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR DpDatadW" Cycle=Rfe PosRR PosRW PosWR DpDatadW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRW PosRR Pod*W DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR DpDatadW { 0:r2=z; 0:r4=x; 1:r2=x; 1:r7=y; 1:r9=z; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | li r4,2 ; stw r3,0(r4) | stw r4,0(r2) ; | lwz r5,0(r2) ; | xor r6,r5,r5 ; | addi r6,r6,1 ; | stw r6,0(r7) ; | li r8,1 ; | stw r8,0(r9) ; Observed 0:r1=1; 1:r1=1; x=2;
