ARM CO-LB+fri+pos-fri "Fri Rfe PosRR Fri Rfe" Cycle=Rfe Fri Rfe PosRR Fri Prefetch=0:x=F,0:x=W,1:x=F,1:x=W Com=Rf Rf Orig=Fri Rfe PosRR Fri Rfe { %x0=x; %x1=x; } P0 | P1 ; LDR R0,[%x0] | LDR R0,[%x1] ; MOV R1,#1 | LDR R1,[%x1] ; STR R1,[%x0] | MOV R2,#2 ; | STR R2,[%x1] ; Observed 0:R0=0; 1:R0=1; 1:R1=0; x=2;
