ARM W+RWC+dmb+dsb.st+dsb.st "DMBdWW Rfe DSB.STdRR Fre DSB.STdWR Fre" Cycle=Rfe DSB.STdRR Fre DSB.STdWR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:z=T,2:z=F,2:x=T Com=Rf Fr Fr Orig=DMBdWW Rfe DSB.STdRR Fre DSB.STdWR Fre { %x0=x; %y0=y; %y1=y; %z1=z; %z2=z; %x2=x; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%y1] | MOV R0,#1 ; STR R0,[%x0] | DSB ST | STR R0,[%z2] ; DMB | LDR R1,[%z1] | DSB ST ; MOV R1,#1 | | LDR R1,[%x2] ; STR R1,[%y0] | | ; Observed 1:R0=1; 1:R1=0; 2:R1=0;
