ARM 3.LB+dsb+data+dsb.st "DSBdRW Rfe DpDatadW Rfe DSB.STdRW Rfe" Cycle=Rfe DSBdRW Rfe DpDatadW Rfe DSB.STdRW Prefetch=0:x=F,0:y=W,1:y=F,1:z=W,2:z=F,2:x=W Com=Rf Rf Rf Orig=DSBdRW Rfe DpDatadW Rfe DSB.STdRW Rfe { %x0=x; %y0=y; %y1=y; %z1=z; %z2=z; %x2=x; } P0 | P1 | P2 ; LDR R0,[%x0] | LDR R0,[%y1] | LDR R0,[%z2] ; DSB | EOR R1,R0,R0 | DSB ST ; MOV R1,#1 | ADD R1,R1,#1 | MOV R1,#1 ; STR R1,[%y0] | STR R1,[%z1] | STR R1,[%x2] ; Observed 0:R0=1; 1:R0=1; 2:R0=1;
