Test S+dmb+fri-rfi-ctrl-wsi-rfi-data
Executions for behaviour: "1:R0=1 ; 1:R2=2 ; 1:R5=2 ; x=2 ; y=2 ; z=2"
ARM S+dmb+fri-rfi-ctrl-wsi-rfi-data
"DMBdWW Rfe Fri Rfi DpCtrldW Wsi Rfi DpDatadW Wse"
Cycle=Rfi DpDatadW Wse DMBdWW Rfe Fri Rfi DpCtrldW Wsi
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe Fri Rfi DpCtrldW Wsi Rfi DpDatadW Wse
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0           | P1           ;
 MOV R0,#2    | LDR R0,[%y1] ;
 STR R0,[%x0] | MOV R1,#2    ;
 DMB          | STR R1,[%y1] ;
 MOV R1,#1    | LDR R2,[%y1] ;
 STR R1,[%y0] | CMP R2,R2    ;
              | BNE LC00     ;
              | LC00:        ;
              | MOV R3,#1    ;
              | STR R3,[%z1] ;
              | MOV R4,#2    ;
              | STR R4,[%z1] ;
              | LDR R5,[%z1] ;
              | EOR R6,R5,R5 ;
              | ADD R6,R6,#1 ;
              | STR R6,[%x1] ;
Observed
    1:R0=1; 1:R2=2; 1:R5=2; x=2; y=2; z=2;
