Test LB+data+fri-rfi-data
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=2 ; y=2"
ARM LB+data+fri-rfi-data
"DpDatadW Rfe Fri Rfi DpDatadW Rfe"
Cycle=Rfi DpDatadW Rfe DpDatadW Rfe Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe Fri Rfi DpDatadW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0           | P1           ;
 LDR R0,[%x0] | LDR R0,[%y1] ;
 EOR R1,R0,R0 | MOV R1,#2    ;
 ADD R1,R1,#1 | STR R1,[%y1] ;
 STR R1,[%y0] | LDR R2,[%y1] ;
              | EOR R3,R2,R2 ;
              | ADD R3,R3,#1 ;
              | STR R3,[%x1] ;
Observed
    0:R0=1; 1:R0=1; 1:R2=2; y=2;
