ARM DETOUR0657 "DMBdWW Rfe DpDatadW DetourW DpAddrdR Fre" Cycle=Rfe DpDatadW DetourW DpAddrdR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DpDatadW DetourW DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; %z2=z; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%y1] | MOV R0,#2 ; STR R0,[%x0] | EOR R1,R0,R0 | STR R0,[%z2] ; DMB | ADD R1,R1,#1 | ; MOV R1,#1 | STR R1,[%z1] | ; STR R1,[%y0] | LDR R2,[%z1] | ; | EOR R3,R2,R2 | ; | LDR R4,[R3,%x1] | ; Observed 1:R0=1; 1:R2=2; 1:R4=0;
