ARM MP+dmb+fri-rfi-ctrl-rfi-ctrl-rfi "DMBdWW Rfe Fri Rfi DpCtrldW Rfi DpCtrldW Rfi Fre" Cycle=Rfi Fre DMBdWW Rfe Fri Rfi DpCtrldW Rfi DpCtrldW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe Fri Rfi DpCtrldW Rfi DpCtrldW Rfi Fre { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | MOV R1,#2 ; DMB | STR R1,[%y1] ; MOV R1,#1 | LDR R2,[%y1] ; STR R1,[%y0] | CMP R2,R2 ; | BNE LC00 ; | LC00: ; | MOV R3,#1 ; | STR R3,[%z1] ; | LDR R4,[%z1] ; | CMP R4,R4 ; | BNE LC01 ; | LC01: ; | MOV R5,#1 ; | STR R5,[%x1] ; | LDR R6,[%x1] ; Observed 1:R0=0; 1:R2=2; 1:R4=1; 1:R6=2; x=2; y=2;
