ARM MP+dmb+addr-pos-addr "DMBdWW Rfe DpAddrdR PosRR DpAddrdR Fre" Cycle=Rfe DpAddrdR PosRR DpAddrdR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DpAddrdR PosRR DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0,#1 | LDR R0,[%y1] ; STR R0,[%x0] | EOR R1,R0,R0 ; DMB | LDR R2,[R1,%z1] ; MOV R1,#1 | LDR R3,[%z1] ; STR R1,[%y0] | EOR R4,R3,R3 ; | LDR R5,[R4,%x1] ; Observed 1:R0=1; 1:R5=0;
