ARM MP+dmb+addr-fri-rfi-addr "DMBdWW Rfe DpAddrdR Fri Rfi DpAddrdR Fre" Cycle=Rfi DpAddrdR Fre DMBdWW Rfe DpAddrdR Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DpAddrdR Fri Rfi DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0,#1 | LDR R0,[%y1] ; STR R0,[%x0] | EOR R1,R0,R0 ; DMB | LDR R2,[R1,%z1] ; MOV R1,#1 | MOV R3,#1 ; STR R1,[%y0] | STR R3,[%z1] ; | LDR R4,[%z1] ; | EOR R5,R4,R4 ; | LDR R6,[R5,%x1] ; Observed 1:R0=1; 1:R2=0; 1:R4=1; 1:R6=0;
