Test MP+PPO678
ARM MP+PPO678
"Fre DMBdWW Rfe PosRW PosWR PosRR DpDatadW PosWR"
Cycle=Rfe PosRW PosWR PosRR DpDatadW PosWR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWR PosRW PosRR DMBdWW DpDatadW
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRW PosWR PosRR DpDatadW PosWR
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0            | P1             ;
 MOV R0, #2    | LDR R0, [%y1]  ;
 STR R0, [%x0] | MOV R1, #2     ;
 DMB           | STR R1, [%y1]  ;
 MOV R1, #1    | LDR R2, [%y1]  ;
 STR R1, [%y0] | LDR R3, [%y1]  ;
               | EOR R4,R3,R3   ;
               | ADD R4, R4, #1 ;
               | STR R4, [%x1]  ;
               | LDR R5, [%x1]  ;
Observed
    1:R0=0; 1:R5=2; x=2; y=2;
