Test MP+PPO619
ARM MP+PPO619
"Fre DMBdWW Rfe PosRW PosWR DpAddrdW PosWR DpDatadW PosWR"
Cycle=Rfe PosRW PosWR DpAddrdW PosWR DpDatadW PosWR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWR PosRW DMBdWW DpAddrdW DpDatadW
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRW PosWR DpAddrdW PosWR DpDatadW PosWR
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0            | P1               ;
 MOV R0, #2    | LDR R0, [%y1]    ;
 STR R0, [%x0] | MOV R1, #2       ;
 DMB           | STR R1, [%y1]    ;
 MOV R1, #1    | LDR R2, [%y1]    ;
 STR R1, [%y0] | EOR R3,R2,R2     ;
               | MOV R4, #1       ;
               | STR R4, [R3,%z1] ;
               | LDR R5, [%z1]    ;
               | EOR R6,R5,R5     ;
               | ADD R6, R6, #1   ;
               | STR R6, [%x1]    ;
               | LDR R7, [%x1]    ;
Observed
    1:R0=0; 1:R7=2; x=2; y=2;
