ARM DETOUR0852 "DMBdWW Wse PosWR Fri Rfi DpCtrlIsbdR Fre" Cycle=Rfi DpCtrlIsbdR Fre DMBdWW Wse PosWR Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Ws Fr Orig=DMBdWW Wse PosWR Fri Rfi DpCtrlIsbdR Fre { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#1 | MOV R0,#2 ; STR R0,[%x0] | STR R0,[%y1] ; DMB | LDR R1,[%y1] ; MOV R1,#1 | MOV R2,#3 ; STR R1,[%y0] | STR R2,[%y1] ; DMB | LDR R3,[%y1] ; LDR R2,[%y0] | CMP R3,R3 ; | BNE LC00 ; | LC00: ; | ISB ; | LDR R4,[%x1] ; Observed 0:R2=3; 1:R1=1; 1:R3=3; 1:R4=1;
