Test DETOUR0710
ARM DETOUR0710
"DMBdWW Rfe PodRR Fri Rfi PosRR Fre"
Cycle=Rfi PosRR Fre DMBdWW Rfe PodRR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe PodRR Fri Rfi PosRR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0           | P1           ;
 MOV R0,#2    | LDR R0,[%y1] ;
 STR R0,[%x0] | LDR R1,[%x1] ;
 DMB          | MOV R2,#1    ;
 MOV R1,#1    | STR R2,[%x1] ;
 STR R1,[%y0] | LDR R3,[%x1] ;
              | LDR R4,[%x1] ;
Observed
    1:R0=1; 1:R1=0; 1:R3=1; 1:R4=2; x=2;
and 1:R0=1; 1:R1=0; 1:R3=2; 1:R4=2; x=2;
