Test DETOUR0653
ARM DETOUR0653
"DMBdWW Rfe DetourR Fri Rfi DpAddrdR Fre"
Cycle=Rfi DpAddrdR Fre DMBdWW Rfe DetourR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe DetourR Fri Rfi DpAddrdR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
 P0           | P1              | P2           ;
 MOV R0,#1    | LDR R0,[%y1]    | MOV R0,#2    ;
 STR R0,[%x0] | LDR R1,[%y1]    | STR R0,[%y2] ;
 DMB          | MOV R2,#3       |              ;
 MOV R1,#1    | STR R2,[%y1]    |              ;
 STR R1,[%y0] | LDR R3,[%y1]    |              ;
              | EOR R4,R3,R3    |              ;
              | LDR R5,[R4,%x1] |              ;
Observed
    1:R0=1; 1:R1=2; 1:R3=3; 1:R5=0;
and 1:R0=0; 1:R1=2; 1:R3=1; 1:R5=1;
and 1:R0=0; 1:R1=1; 1:R3=2; 1:R5=1;
