Test MP+dmb+pos-fri-rfi-ctrlisb
Executions for behaviour: "1:R0=0 ; 1:R1=1 ; 1:R3=2 ; 1:R4=0 ; y=2"
Executions for behaviour: "1:R0=1 ; 1:R1=1 ; 1:R3=2 ; 1:R4=0 ; y=2"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=2 ; 1:R4=1 ; y=2"
ARM MP+dmb+pos-fri-rfi-ctrlisb
"DMBdWW Rfe PosRR Fri Rfi DpCtrlIsbdR Fre"
Cycle=Rfi DpCtrlIsbdR Fre DMBdWW Rfe PosRR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe PosRR Fri Rfi DpCtrlIsbdR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0           | P1           ;
 MOV R0,#1    | LDR R0,[%y1] ;
 STR R0,[%x0] | LDR R1,[%y1] ;
 DMB          | MOV R2,#2    ;
 MOV R1,#1    | STR R2,[%y1] ;
 STR R1,[%y0] | LDR R3,[%y1] ;
              | CMP R3,R3    ;
              | BNE LC00     ;
              | LC00:        ;
              | ISB          ;
              | LDR R4,[%x1] ;
Observed
    1:R0=0; 1:R1=1; 1:R3=2; 1:R4=0; y=2;
and 1:R0=1; 1:R1=1; 1:R3=2; 1:R4=0; y=2;
and 1:R0=1; 1:R1=0; 1:R3=2; 1:R4=1; y=2;
