Test DETOUR0808
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=0 ; 1:R4=0 ; x=1"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=1 ; 1:R4=1 ; x=1"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=2 ; 1:R4=2 ; x=1"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=2 ; 1:R4=2 ; x=1"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=0 ; 1:R4=0 ; x=2"
Executions for behaviour: "1:R0=2 ; 1:R1=2 ; 1:R3=1 ; 1:R4=0 ; x=2"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=1 ; 1:R4=1 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=2 ; 1:R4=2 ; x=2"
ARM DETOUR0808
"DMBdWW Rfe DetourR DpAddrdR DetourR Fre"
Cycle=Rfe DetourR DpAddrdR DetourR Fre DMBdWW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe DetourR DpAddrdR DetourR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
%x3=x;
 P0           | P1              | P2           | P3           ;
 MOV R0,#2    | LDR R0,[%y1]    | MOV R0,#2    | MOV R0,#1    ;
 STR R0,[%x0] | LDR R1,[%y1]    | STR R0,[%y2] | STR R0,[%x3] ;
 DMB          | EOR R2,R1,R1    |              |              ;
 MOV R1,#1    | LDR R3,[R2,%x1] |              |              ;
 STR R1,[%y0] | LDR R4,[%x1]    |              |              ;
Observed
    1:R0=2; 1:R1=0; 1:R3=0; 1:R4=0; x=1;
and 1:R0=1; 1:R1=0; 1:R3=1; 1:R4=1; x=1;
and 1:R0=1; 1:R1=0; 1:R3=2; 1:R4=2; x=1;
and 1:R0=2; 1:R1=0; 1:R3=2; 1:R4=2; x=1;
and 1:R0=2; 1:R1=0; 1:R3=0; 1:R4=0; x=2;
and 1:R0=2; 1:R1=2; 1:R3=1; 1:R4=0; x=2;
and 1:R0=2; 1:R1=0; 1:R3=1; 1:R4=1; x=2;
and 1:R0=1; 1:R1=0; 1:R3=2; 1:R4=2; x=2;
