Test DETOUR0701
Executions for behaviour: "1:R0=0 ; 1:R3=2 ; 1:R4=1 ; x=2"
ARM DETOUR0701
"DMBdWW Rfe DpAddrdW Rfi PosRR Fre"
Cycle=Rfi PosRR Fre DMBdWW Rfe DpAddrdW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe DpAddrdW Rfi PosRR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0           | P1              ;
 MOV R0,#2    | LDR R0,[%y1]    ;
 STR R0,[%x0] | EOR R1,R0,R0    ;
 DMB          | MOV R2,#1       ;
 MOV R1,#1    | STR R2,[R1,%x1] ;
 STR R1,[%y0] | LDR R3,[%x1]    ;
              | LDR R4,[%x1]    ;
Observed
    1:R0=0; 1:R3=2; 1:R4=1; x=2;
