Test DETOUR0663
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R2=1 ; 1:R4=1"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R2=2 ; 1:R4=1"
ARM DETOUR0663
"DMBdWW Rfe PosRR DetourR DpAddrdR Fre"
Cycle=Rfe PosRR DetourR DpAddrdR Fre DMBdWW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe PosRR DetourR DpAddrdR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
 P0           | P1              | P2           ;
 MOV R0,#1    | LDR R0,[%y1]    | MOV R0,#2    ;
 STR R0,[%x0] | LDR R1,[%y1]    | STR R0,[%y2] ;
 DMB          | LDR R2,[%y1]    |              ;
 MOV R1,#1    | EOR R3,R2,R2    |              ;
 STR R1,[%y0] | LDR R4,[R3,%x1] |              ;
Observed
    1:R0=1; 1:R1=0; 1:R2=1; 1:R4=1;
and 1:R0=2; 1:R1=0; 1:R2=2; 1:R4=1;
