Test DETOUR0713
Executions for behaviour: "1:R0=0 ; 1:R3=2 ; 1:R4=1 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R3=2 ; 1:R4=1 ; x=2"
Executions for behaviour: "1:R0=0 ; 1:R3=3 ; 1:R4=1 ; x=3"
ARM DETOUR0713
"DMBdWW Rfe DpAddrdW DetourW PosRR Fre"
Cycle=Rfe DpAddrdW DetourW PosRR Fre DMBdWW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe DpAddrdW DetourW PosRR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
%x2=x;
 P0           | P1              | P2           ;
 MOV R0,#3    | LDR R0,[%y1]    | MOV R0,#2    ;
 STR R0,[%x0] | EOR R1,R0,R0    | STR R0,[%x2] ;
 DMB          | MOV R2,#1       |              ;
 MOV R1,#1    | STR R2,[R1,%x1] |              ;
 STR R1,[%y0] | LDR R3,[%x1]    |              ;
              | LDR R4,[%x1]    |              ;
Observed
    1:R0=0; 1:R3=2; 1:R4=1; x=2;
and 1:R0=1; 1:R3=2; 1:R4=1; x=2;
and 1:R0=0; 1:R3=3; 1:R4=1; x=3;
