Test LB+PPO0528
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; y=2"
ARM LB+PPO0528
"PodWW Rfe DpDatadW Rfe DpDatadW PosWR PosRR PosRW"
Cycle=Rfe DpDatadW Rfe DpDatadW PosWR PosRR PosRW PodWW
Relax=
Safe=Rfe PosWR PosRW PosRR Pod*W DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodWW Rfe DpDatadW Rfe DpDatadW PosWR PosRR PosRW
%z0=z; %x0=x;
%x1=x; %y1=y; %z1=z;
 P0           | P1           ;
 LDR R0,[%z0] | LDR R0,[%x1] ;
 EOR R1,R0,R0 | EOR R1,R0,R0 ;
 ADD R1,R1,#1 | ADD R1,R1,#1 ;
 STR R1,[%x0] | STR R1,[%y1] ;
              | LDR R2,[%y1] ;
              | LDR R3,[%y1] ;
              | MOV R4,#2    ;
              | STR R4,[%y1] ;
              | MOV R5,#1    ;
              | STR R5,[%z1] ;
Observed
    0:R0=1; 1:R0=1; y=2;
