ARM LB+PPO0347 "PodWW Rfe DpDatadW Rfe PosRR DpDatadW PosWW" Cycle=Rfe PosRR DpDatadW PosWW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWW PosRR Pod*W DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR DpDatadW PosWW { %z0=z; %x0=x; %x1=x; %y1=y; %z1=z; } P0 | P1 ; LDR R0,[%z0] | LDR R0,[%x1] ; EOR R1,R0,R0 | LDR R1,[%x1] ; ADD R1,R1,#1 | EOR R2,R1,R1 ; STR R1,[%x0] | ADD R2,R2,#1 ; | STR R2,[%y1] ; | MOV R3,#2 ; | STR R3,[%y1] ; | MOV R4,#1 ; | STR R4,[%z1] ; Observed 0:R0=1; 1:R0=1; y=2;
