Executions for behaviour:
"1:R0=1 ; 1:R4=0"
ARM MP0161 "DMBdWW Rfe DpAddrdR DpDatadW PodWR Fre" Cycle=Rfe DpAddrdR DpDatadW PodWR Fre DMBdWW Relax=[Fre,DMBdWW,Rfe] Safe=PodWR DpAddrdR DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DpAddrdR DpDatadW PodWR Fre { %x0=x; %y0=y; %y1=y; %z1=z; %a1=a; %x1=x; } P0 | P1 ; MOV R0,#1 | LDR R0,[%y1] ; STR R0,[%x0] | EOR R1,R0,R0 ; DMB | LDR R2,[R1,%z1] ; MOV R1,#1 | EOR R3,R2,R2 ; STR R1,[%y0] | ADD R3,R3,#1 ; | STR R3,[%a1] ; | LDR R4,[%x1] ; Observed 1:R0=1; 1:R4=0;
