Executions for behaviour:
"1:R0=1 ; 1:R7=0"
ARM MP+PPO826 "Fre DMBdWW Rfe DpDatadW PosWR DpCtrldW PosWR DpAddrdR PosRR" Cycle=Rfe DpDatadW PosWR DpCtrldW PosWR DpAddrdR PosRR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRR DMBdWW DpAddrdR DpDatadW DpCtrldW Prefetch=1:x=T Orig=Fre DMBdWW Rfe DpDatadW PosWR DpCtrldW PosWR DpAddrdR PosRR { %x0=x; %y0=y; %y1=y; %z1=z; %a1=a; %x1=x; } P0 | P1 ; MOV R0, #1 | LDR R0, [%y1] ; STR R0, [%x0] | EOR R1,R0,R0 ; DMB | ADD R1, R1, #1 ; MOV R1, #1 | STR R1, [%z1] ; STR R1, [%y0] | LDR R2, [%z1] ; | CMP R2, R2 ; | BNE LC00 ; | LC00: ; | MOV R3, #1 ; | STR R3, [%a1] ; | LDR R4, [%a1] ; | EOR R5,R4,R4 ; | LDR R6, [R5,%x1] ; | LDR R7, [%x1] ; Observed 1:R0=1; 1:R7=0;
