Executions for behaviour:
"1:R0=1 ; 1:R7=0"
ARM MP+PPO207 "Fre DMBdWW Rfe DpAddrdR PosRW PosWR PosRR DpAddrdR" Cycle=Rfe DpAddrdR PosRW PosWR PosRR DpAddrdR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR DMBdWW DpAddrdR Prefetch=1:x=T Orig=Fre DMBdWW Rfe DpAddrdR PosRW PosWR PosRR DpAddrdR { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0, #1 | LDR R0, [%y1] ; STR R0, [%x0] | EOR R1,R0,R0 ; DMB | LDR R2, [R1,%z1] ; MOV R1, #1 | MOV R3, #1 ; STR R1, [%y0] | STR R3, [%z1] ; | LDR R4, [%z1] ; | LDR R5, [%z1] ; | EOR R6,R5,R5 ; | LDR R7, [R6,%x1] ; Observed 1:R0=1; 1:R7=0;
