Test MOREDETOUR0532
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 1:R5=0"
ARM MOREDETOUR0532
"DMBdWW Rfe DpAddrdR Fri Rfi DpCtrldR Fre"
Cycle=Rfi DpCtrldR Fre DMBdWW Rfe DpAddrdR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe DpAddrdR Fri Rfi DpCtrldR Fre
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0           | P1              ;
 MOV R0,#1    | LDR R0,[%y1]    ;
 STR R0,[%x0] | EOR R1,R0,R0    ;
 DMB          | LDR R2,[R1,%z1] ;
 MOV R1,#1    | MOV R3,#1       ;
 STR R1,[%y0] | STR R3,[%z1]    ;
              | LDR R4,[%z1]    ;
              | CMP R4,R4       ;
              | BNE LC00        ;
              | LC00:           ;
              | LDR R5,[%x1]    ;
Observed
    1:R0=1; 1:R2=0; 1:R4=1; 1:R5=0;
