Executions for behaviour:
"0:R2=3 ; 1:R1=1 ; 1:R3=0"
ARM DETOUR0889 "DMBdWW Wse PosWR Fri PodWR Fre" Cycle=Fri PodWR Fre DMBdWW Wse PosWR Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Ws Fr Orig=DMBdWW Wse PosWR Fri PodWR Fre { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#1 | MOV R0,#2 ; STR R0,[%x0] | STR R0,[%y1] ; DMB | LDR R1,[%y1] ; MOV R1,#1 | MOV R2,#3 ; STR R1,[%y0] | STR R2,[%y1] ; DMB | LDR R3,[%x1] ; LDR R2,[%y0] | ; Observed 0:R2=3; 1:R1=1; 1:R3=0;
