Test DETOUR0650
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 1:R6=0"
ARM DETOUR0650
"DMBdWW Rfe DpAddrdR Fri Rfi DpAddrdR Fre"
Cycle=Rfi DpAddrdR Fre DMBdWW Rfe DpAddrdR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe DpAddrdR Fri Rfi DpAddrdR Fre
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0           | P1              ;
 MOV R0,#1    | LDR R0,[%y1]    ;
 STR R0,[%x0] | EOR R1,R0,R0    ;
 DMB          | LDR R2,[R1,%z1] ;
 MOV R1,#1    | MOV R3,#1       ;
 STR R1,[%y0] | STR R3,[%z1]    ;
              | LDR R4,[%z1]    ;
              | EOR R5,R4,R4    ;
              | LDR R6,[R5,%x1] ;
Observed
    1:R0=1; 1:R2=0; 1:R4=1; 1:R6=0;
