ARM MOREDETOUR0443 "DMBdWW Rfe DetourRW Rfi DpAddrdR Fre" Cycle=Rfi DpAddrdR Fre DMBdWW Rfe DetourRW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DetourRW Rfi DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%y1] | LDR R0,[%y2] ; STR R0,[%x0] | MOV R1,#3 | MOV R1,#2 ; DMB | STR R1,[%y1] | STR R1,[%y2] ; MOV R1,#1 | LDR R2,[%y1] | ; STR R1,[%y0] | EOR R3,R2,R2 | ; | LDR R4,[R3,%x1] | ; Observed 1:R0=0; 1:R2=2; 1:R4=0; 2:R0=0; y=2; and 1:R0=0; 1:R2=2; 1:R4=0; 2:R0=3; y=2;
