ARM MOREDETOUR0201 "DpDatadW Rfe DpAddrdR PosRR DetourRW Rfe" Cycle=Rfe DpAddrdR PosRR DetourRW Rfe DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DpAddrdR PosRR DetourRW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; } P0 | P1 | P2 ; LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#1 ; EOR R1,R0,R0 | EOR R1,R0,R0 | STR R0,[%x2] ; ADD R1,R1,#1 | LDR R2,[R1,%x1] | ; STR R1,[%y0] | LDR R3,[%x1] | ; | MOV R4,#2 | ; | STR R4,[%x1] | ; Observed 0:R0=1; 1:R0=1; 1:R3=0; x=1; and 0:R0=1; 1:R0=1; 1:R3=0; x=2;
