ARM MOREDETOUR0003 "DetourWW PodWR Fri Rfe DpAddrdR Fre" Cycle=Rfe DpAddrdR Fre DetourWW PodWR Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DetourWW PodWR Fri Rfe DpAddrdR Fre { %x0=x; %y0=y; %x1=x; %y2=y; %x2=x; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%x1] | LDR R0,[%y2] ; STR R0,[%x0] | MOV R1,#2 | EOR R1,R0,R0 ; MOV R1,#3 | STR R1,[%x1] | LDR R2,[R1,%x2] ; STR R1,[%x0] | | ; LDR R2,[%y0] | | ; MOV R3,#1 | | ; STR R3,[%y0] | | ; Observed 0:R2=0; 1:R0=1; 2:R0=1; 2:R2=0; x=2; and 0:R2=0; 1:R0=1; 2:R0=1; 2:R2=0; x=3;
