ARM LB+data+fri-detw-addr "DpDatadW Rfe Fri DetourW DpAddrdW Rfe" Cycle=Rfe Fri DetourW DpAddrdW Rfe DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe Fri DetourW DpAddrdW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; } P0 | P1 | P2 ; LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#3 ; EOR R1,R0,R0 | MOV R1,#2 | STR R0,[%y2] ; ADD R1,R1,#1 | STR R1,[%y1] | ; STR R1,[%y0] | LDR R2,[%y1] | ; | EOR R3,R2,R2 | ; | MOV R4,#1 | ; | STR R4,[R3,%x1] | ; Observed 0:R0=1; 1:R0=0; 1:R2=3; y=3;
