ARM DETOUR0437 "PosWR Fri Rfi DpCtrldW Rfe DpDatadW Wse" Cycle=Rfi DpCtrldW Rfe DpDatadW Wse PosWR Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=PosWR Fri Rfi DpCtrldW Rfe DpDatadW Wse { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | EOR R1,R0,R0 ; LDR R1,[%x0] | ADD R1,R1,#1 ; MOV R2,#3 | STR R1,[%x1] ; STR R2,[%x0] | DMB ; LDR R3,[%x0] | LDR R2,[%x1] ; CMP R3,R3 | ; BNE LC00 | ; LC00: | ; MOV R4,#1 | ; STR R4,[%y0] | ; Observed 0:R1=2; 0:R3=3; 1:R0=1; 1:R2=2;
