ARM DETOUR0044 "DetourW DpAddrdR DpAddrdW Rfe DpAddrdR Fre" Cycle=Rfe DpAddrdR Fre DetourW DpAddrdR DpAddrdW Prefetch=0:x=F,0:z=W,1:z=F,1:x=T Com=Rf Fr Orig=DetourW DpAddrdR DpAddrdW Rfe DpAddrdR Fre { %x0=x; %y0=y; %z0=z; %x1=x; %z2=z; %x2=x; } P0 | P1 | P2 ; MOV R0,#1 | MOV R0,#2 | LDR R0,[%z2] ; STR R0,[%x0] | STR R0,[%x1] | EOR R1,R0,R0 ; LDR R1,[%x0] | | LDR R2,[R1,%x2] ; EOR R2,R1,R1 | | ; LDR R3,[R2,%y0] | | ; EOR R4,R3,R3 | | ; MOV R5,#1 | | ; STR R5,[R4,%z0] | | ; Observed 0:R1=2; 2:R0=1; 2:R2=0; and 0:R1=2; 2:R0=1; 2:R2=1;
