Test S+dmb+pos-fri-rfi-data
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=2 ; x=1 ; y=2"
Executions for behaviour: "1:R0=0 ; 1:R1=1 ; 1:R3=2 ; x=2 ; y=2"
Executions for behaviour: "1:R0=1 ; 1:R1=1 ; 1:R3=2 ; x=2 ; y=2"
ARM S+dmb+pos-fri-rfi-data
"DMBdWW Rfe PosRR Fri Rfi DpDatadW Wse"
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe PosRR Fri Rfi DpDatadW Wse
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0           | P1           ;
 MOV R0,#2    | LDR R0,[%y1] ;
 STR R0,[%x0] | LDR R1,[%y1] ;
 DMB          | MOV R2,#2    ;
 MOV R1,#1    | STR R2,[%y1] ;
 STR R1,[%y0] | LDR R3,[%y1] ;
              | EOR R4,R3,R3 ;
              | ADD R4,R4,#1 ;
              | STR R4,[%x1] ;
Observed
    1:R0=1; 1:R1=0; 1:R3=2; x=1; y=2;
and 1:R0=0; 1:R1=1; 1:R3=2; x=2; y=2;
and 1:R0=1; 1:R1=1; 1:R3=2; x=2; y=2;
