Executions for behaviour:
"1:R0=0 ; 1:R2=1 ; 1:R3=2 ; 1:R5=1 ; x=1 ; y=1"
"1:R0=0 ; 1:R2=1 ; 1:R3=2 ; 1:R5=1 ; x=2 ; y=1"
"1:R0=1 ; 1:R2=2 ; 1:R3=2 ; 1:R5=1 ; x=2 ; y=2"
ARM S+dmb+fri-rfi-pos-ctrl-rfi-addr "DMBdWW Rfe Fri Rfi PosRR DpCtrldW Rfi DpAddrdW Wse" Cycle=Rfi PosRR DpCtrldW Rfi DpAddrdW Wse DMBdWW Rfe Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe Fri Rfi PosRR DpCtrldW Rfi DpAddrdW Wse { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | MOV R1,#2 ; DMB | STR R1,[%y1] ; MOV R1,#1 | LDR R2,[%y1] ; STR R1,[%y0] | LDR R3,[%y1] ; | CMP R3,R3 ; | BNE LC00 ; | LC00: ; | MOV R4,#1 ; | STR R4,[%z1] ; | LDR R5,[%z1] ; | EOR R6,R5,R5 ; | MOV R7,#1 ; | STR R7,[R6,%x1] ; Observed 1:R0=0; 1:R2=1; 1:R3=2; 1:R5=1; x=1; y=1; and 1:R0=0; 1:R2=1; 1:R3=2; 1:R5=1; x=2; y=1; and 1:R0=1; 1:R2=2; 1:R3=2; 1:R5=1; x=2; y=2;
