Test S+dmb+detr-fri-rfi-data
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=1 ; 1:R5=1 ; x=1 ; y=1"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=3 ; 1:R5=1 ; x=1 ; y=1"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=3 ; 1:R5=1 ; x=2 ; y=1"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=3 ; 1:R5=2 ; x=2 ; y=1"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=2 ; 1:R5=1 ; x=1 ; y=2"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=3 ; 1:R5=1 ; x=1 ; y=2"
Executions for behaviour: "1:R0=1 ; 1:R1=1 ; 1:R3=3 ; 1:R5=2 ; x=2 ; y=2"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=3 ; 1:R5=1 ; x=1 ; y=3"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=3 ; 1:R5=1 ; x=1 ; y=3"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=3 ; 1:R5=2 ; x=2 ; y=3"
Executions for behaviour: "1:R0=1 ; 1:R1=1 ; 1:R3=3 ; 1:R5=2 ; x=2 ; y=3"
ARM S+dmb+detr-fri-rfi-data
"DMBdWW Rfe DetourR Fri Rfi DpDatadW Wse"
Cycle=Rfi DpDatadW Wse DMBdWW Rfe DetourR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe DetourR Fri Rfi DpDatadW Wse
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
 P0           | P1           | P2           ;
 MOV R0,#2    | LDR R0,[%y1] | MOV R0,#2    ;
 STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%y2] ;
 DMB          | MOV R2,#3    |              ;
 MOV R1,#1    | STR R2,[%y1] |              ;
 STR R1,[%y0] | LDR R3,[%y1] |              ;
              | EOR R4,R3,R3 |              ;
              | ADD R4,R4,#1 |              ;
              | STR R4,[%x1] |              ;
              | DMB          |              ;
              | LDR R5,[%x1] |              ;
Observed
    1:R0=2; 1:R1=0; 1:R3=1; 1:R5=1; x=1; y=1;
and 1:R0=2; 1:R1=0; 1:R3=3; 1:R5=1; x=1; y=1;
and 1:R0=2; 1:R1=0; 1:R3=3; 1:R5=1; x=2; y=1;
and 1:R0=2; 1:R1=0; 1:R3=3; 1:R5=2; x=2; y=1;
and 1:R0=1; 1:R1=0; 1:R3=2; 1:R5=1; x=1; y=2;
and 1:R0=1; 1:R1=0; 1:R3=3; 1:R5=1; x=1; y=2;
and 1:R0=1; 1:R1=1; 1:R3=3; 1:R5=2; x=2; y=2;
and 1:R0=1; 1:R1=0; 1:R3=3; 1:R5=1; x=1; y=3;
and 1:R0=2; 1:R1=0; 1:R3=3; 1:R5=1; x=1; y=3;
and 1:R0=2; 1:R1=0; 1:R3=3; 1:R5=2; x=2; y=3;
and 1:R0=1; 1:R1=1; 1:R3=3; 1:R5=2; x=2; y=3;
