Executions for behaviour:
"1:R0=0 ; 1:R3=2 ; 1:R5=2 ; 1:R6=0 ; x=1 ; z=2"
"1:R0=1 ; 1:R3=2 ; 1:R5=2 ; 1:R6=0 ; x=1 ; z=2"
"1:R0=1 ; 1:R3=2 ; 1:R5=0 ; 1:R6=0 ; x=2 ; z=2"
ARM S+dmb+data-wsi-rfi-addr-pos-fri "DMBdWW Rfe DpDatadW Wsi Rfi DpAddrdR PosRR Fri Wse" Cycle=Rfi DpAddrdR PosRR Fri Wse DMBdWW Rfe DpDatadW Wsi Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe DpDatadW Wsi Rfi DpAddrdR PosRR Fri Wse { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | EOR R1,R0,R0 ; DMB | ADD R1,R1,#1 ; MOV R1,#1 | STR R1,[%z1] ; STR R1,[%y0] | MOV R2,#2 ; | STR R2,[%z1] ; | LDR R3,[%z1] ; | EOR R4,R3,R3 ; | LDR R5,[R4,%x1] ; | LDR R6,[%x1] ; | MOV R7,#1 ; | STR R7,[%x1] ; Observed 1:R0=0; 1:R3=2; 1:R5=2; 1:R6=0; x=1; z=2; and 1:R0=1; 1:R3=2; 1:R5=2; 1:R6=0; x=1; z=2; and 1:R0=1; 1:R3=2; 1:R5=0; 1:R6=0; x=2; z=2;
