Test S+PPO556
Executions for behaviour: "1:R0=1 ; x=2 ; z=2"
ARM S+PPO556
"Wse DMBdWW Rfe PosRR DpCtrldW PosWW PosWR PosRR DpDatadW"
Cycle=Rfe PosRR DpCtrldW PosWW PosWR PosRR DpDatadW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWW PosWR PosRR DMBdWW DpDatadW DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRR DpCtrldW PosWW PosWR PosRR DpDatadW
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0            | P1             ;
 MOV R0, #2    | LDR R0, [%y1]  ;
 STR R0, [%x0] | LDR R1, [%y1]  ;
 DMB           | CMP R1, R1     ;
 MOV R1, #1    | BNE LC00       ;
 STR R1, [%y0] | LC00:          ;
               | MOV R2, #1     ;
               | STR R2, [%z1]  ;
               | MOV R3, #2     ;
               | STR R3, [%z1]  ;
               | LDR R4, [%z1]  ;
               | LDR R5, [%z1]  ;
               | EOR R6,R5,R5   ;
               | ADD R6, R6, #1 ;
               | STR R6, [%x1]  ;
Observed
    1:R0=1; x=2; z=2;
