Test S+PPO258
Executions for behaviour: "1:R0=1 ; x=2"
ARM S+PPO258
"Wse DMBdWW Rfe PosRR DpAddrdR DpCtrldW PosWR PosRR DpAddrdW"
Cycle=Rfe PosRR DpAddrdR DpCtrldW PosWR PosRR DpAddrdW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWR PosRR DMBdWW DpAddrdW DpAddrdR DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRR DpAddrdR DpCtrldW PosWR PosRR DpAddrdW
%x0=x; %y0=y;
%y1=y; %z1=z; %a1=a; %x1=x;
 P0            | P1               ;
 MOV R0, #2    | LDR R0, [%y1]    ;
 STR R0, [%x0] | LDR R1, [%y1]    ;
 DMB           | EOR R2,R1,R1     ;
 MOV R1, #1    | LDR R3, [R2,%z1] ;
 STR R1, [%y0] | CMP R3, R3       ;
               | BNE LC00         ;
               | LC00:            ;
               | MOV R4, #1       ;
               | STR R4, [%a1]    ;
               | LDR R5, [%a1]    ;
               | LDR R6, [%a1]    ;
               | EOR R7,R6,R6     ;
               | MOV R8, #1       ;
               | STR R8, [R7,%x1] ;
Observed
    1:R0=1; x=2;
