Executions for behaviour:
"1:R0=1 ; 1:R3=0 ; y=2"
ARM MP0105 "DMBdWW Rfe PosRW PosWR DpCtrlIsbdR Fre" Cycle=Rfe PosRW PosWR DpCtrlIsbdR Fre DMBdWW Relax=[Fre,DMBdWW,Rfe] Safe=PosWR PosRW DpCtrlIsbdR Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe PosRW PosWR DpCtrlIsbdR Fre { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#1 | LDR R0,[%y1] ; STR R0,[%x0] | MOV R1,#2 ; DMB | STR R1,[%y1] ; MOV R1,#1 | LDR R2,[%y1] ; STR R1,[%y0] | CMP R2,R2 ; | BNE LC00 ; | LC00: ; | ISB ; | LDR R3,[%x1] ; Observed 1:R0=1; 1:R3=0; y=2;
