Executions for behaviour:
"1:R0=0 ; 1:R2=1 ; 1:R3=2 ; 1:R5=0 ; y=1"
"1:R0=0 ; 1:R2=1 ; 1:R3=2 ; 1:R5=1 ; y=1"
ARM MP+dmb+fri-rfi-pos-addr "DMBdWW Rfe Fri Rfi PosRR DpAddrdR Fre" Cycle=Rfi PosRR DpAddrdR Fre DMBdWW Rfe Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe Fri Rfi PosRR DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#1 | LDR R0,[%y1] ; STR R0,[%x0] | MOV R1,#2 ; DMB | STR R1,[%y1] ; MOV R1,#1 | LDR R2,[%y1] ; STR R1,[%y0] | LDR R3,[%y1] ; | EOR R4,R3,R3 ; | LDR R5,[R4,%x1] ; Observed 1:R0=0; 1:R2=1; 1:R3=2; 1:R5=0; y=1; and 1:R0=0; 1:R2=1; 1:R3=2; 1:R5=1; y=1;
