Executions for behaviour:
"1:R0=0 ; 1:R2=1 ; 1:R3=2 ; 1:R8=1 ; x=1 ; y=1"
"1:R0=0 ; 1:R2=1 ; 1:R3=2 ; 1:R8=1 ; x=2 ; y=1"
"1:R0=1 ; 1:R2=2 ; 1:R3=2 ; 1:R8=1 ; x=2 ; y=2"
"1:R0=1 ; 1:R2=2 ; 1:R3=2 ; 1:R8=2 ; x=2 ; y=2"
ARM MP+dmb+fri-rfi-pos-addr-addr-rfi "DMBdWW Rfe Fri Rfi PosRR DpAddrdR DpAddrdW Rfi Fre" Cycle=Rfi Fre DMBdWW Rfe Fri Rfi PosRR DpAddrdR DpAddrdW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe Fri Rfi PosRR DpAddrdR DpAddrdW Rfi Fre { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | MOV R1,#2 ; DMB | STR R1,[%y1] ; MOV R1,#1 | LDR R2,[%y1] ; STR R1,[%y0] | LDR R3,[%y1] ; | EOR R4,R3,R3 ; | LDR R5,[R4,%z1] ; | EOR R6,R5,R5 ; | MOV R7,#1 ; | STR R7,[R6,%x1] ; | LDR R8,[%x1] ; Observed 1:R0=0; 1:R2=1; 1:R3=2; 1:R8=1; x=1; y=1; and 1:R0=0; 1:R2=1; 1:R3=2; 1:R8=1; x=2; y=1; and 1:R0=1; 1:R2=2; 1:R3=2; 1:R8=1; x=2; y=2; and 1:R0=1; 1:R2=2; 1:R3=2; 1:R8=2; x=2; y=2;
