Test MP+PPO389
Executions for behaviour: "1:R0=1 ; 1:R6=0 ; y=2 ; z=2"
ARM MP+PPO389
"Fre DMBdWW Rfe PosRW PosWR DpDatadW PosWW PosWR DpCtrlIsbdR"
Cycle=Rfe PosRW PosWR DpDatadW PosWW PosWR DpCtrlIsbdR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWW PosWR PosRW DMBdWW DpDatadW DpCtrlIsbdR
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRW PosWR DpDatadW PosWW PosWR DpCtrlIsbdR
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0            | P1             ;
 MOV R0, #1    | LDR R0, [%y1]  ;
 STR R0, [%x0] | MOV R1, #2     ;
 DMB           | STR R1, [%y1]  ;
 MOV R1, #1    | LDR R2, [%y1]  ;
 STR R1, [%y0] | EOR R3,R2,R2   ;
               | ADD R3, R3, #1 ;
               | STR R3, [%z1]  ;
               | MOV R4, #2     ;
               | STR R4, [%z1]  ;
               | LDR R5, [%z1]  ;
               | CMP R5, R5     ;
               | BNE LC00       ;
               | LC00:          ;
               | ISB            ;
               | LDR R6, [%x1]  ;
Observed
    1:R0=1; 1:R6=0; y=2; z=2;
