Executions for behaviour:
"1:R0=1 ; 1:R3=0"
ARM MP+PPO145 "Fre DMBdWW Rfe PosRR DpAddrdR" Cycle=Rfe PosRR DpAddrdR Fre DMBdWW Relax= Safe=Rfe Fre PosRR DMBdWW DpAddrdR Prefetch=1:x=T Orig=Fre DMBdWW Rfe PosRR DpAddrdR { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0, #1 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | EOR R2,R1,R1 ; MOV R1, #1 | LDR R3, [R2,%x1] ; STR R1, [%y0] | ; Observed 1:R0=1; 1:R3=0;
