Executions for behaviour:
"1:R0=1 ; 1:R3=0 ; 2:R1=1 ; x=1"
"1:R0=1 ; 1:R3=0 ; 2:R1=1 ; x=2"
"1:R0=1 ; 1:R3=0 ; 2:R1=2 ; x=2"
"1:R0=1 ; 1:R3=0 ; 2:R1=3 ; x=2"
"1:R0=1 ; 1:R3=1 ; 2:R1=3 ; x=2"
"1:R0=1 ; 1:R3=0 ; 2:R1=1 ; x=3"
"1:R0=1 ; 1:R3=1 ; 2:R1=1 ; x=3"
"1:R0=1 ; 1:R3=0 ; 2:R1=2 ; x=3"
"1:R0=1 ; 1:R3=0 ; 2:R1=3 ; x=3"
"1:R0=1 ; 1:R3=1 ; 2:R1=3 ; x=3"
ARM MOREDETOUR0786 "DMBdWW Rfe PosRR DpAddrdR DetourRW Wse" Cycle=Rfe PosRR DpAddrdR DetourRW Wse DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe PosRR DpAddrdR DetourRW Wse { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; } P0 | P1 | P2 ; MOV R0,#3 | LDR R0,[%y1] | MOV R0,#1 ; STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%x2] ; DMB | EOR R2,R1,R1 | DMB ; MOV R1,#1 | LDR R3,[R2,%x1] | LDR R1,[%x2] ; STR R1,[%y0] | MOV R4,#2 | ; | STR R4,[%x1] | ; Observed 1:R0=1; 1:R3=0; 2:R1=1; x=1; and 1:R0=1; 1:R3=0; 2:R1=1; x=2; and 1:R0=1; 1:R3=0; 2:R1=2; x=2; and 1:R0=1; 1:R3=0; 2:R1=3; x=2; and 1:R0=1; 1:R3=1; 2:R1=3; x=2; and 1:R0=1; 1:R3=0; 2:R1=1; x=3; and 1:R0=1; 1:R3=1; 2:R1=1; x=3; and 1:R0=1; 1:R3=0; 2:R1=2; x=3; and 1:R0=1; 1:R3=0; 2:R1=3; x=3; and 1:R0=1; 1:R3=1; 2:R1=3; x=3;
