Executions for behaviour:
"1:R0=0 ; 1:R1=1 ; 1:R2=0 ; 1:R4=0"
"1:R0=1 ; 1:R1=1 ; 1:R2=0 ; 1:R4=0"
"1:R0=0 ; 1:R1=1 ; 1:R2=0 ; 1:R4=1"
"1:R0=1 ; 1:R1=1 ; 1:R2=0 ; 1:R4=1"
ARM MOREDETOUR0449 "DMBdWW Rfe DpCtrldR DetourR DpAddrdR Fre" Cycle=Rfe DpCtrldR DetourR DpAddrdR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DpCtrldR DetourR DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; %z2=z; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%y1] | MOV R0,#1 ; STR R0,[%x0] | CMP R0,R0 | STR R0,[%z2] ; DMB | BNE LC00 | ; MOV R1,#1 | LC00: | ; STR R1,[%y0] | LDR R1,[%z1] | ; | LDR R2,[%z1] | ; | EOR R3,R2,R2 | ; | LDR R4,[R3,%x1] | ; Observed 1:R0=0; 1:R1=1; 1:R2=0; 1:R4=0; and 1:R0=1; 1:R1=1; 1:R2=0; 1:R4=0; and 1:R0=0; 1:R1=1; 1:R2=0; 1:R4=1; and 1:R0=1; 1:R1=1; 1:R2=0; 1:R4=1;
