Executions for behaviour:
"0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 1:R3=2 ; y=2"
"0:R0=1 ; 1:R0=0 ; 1:R1=1 ; 1:R3=2 ; y=2"
"0:R0=1 ; 1:R0=1 ; 1:R1=1 ; 1:R3=2 ; y=2"
ARM LB+data+pos-fri-rfi-addr "DpDatadW Rfe PosRR Fri Rfi DpAddrdW Rfe" Cycle=Rfi DpAddrdW Rfe DpDatadW Rfe PosRR Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe PosRR Fri Rfi DpAddrdW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; LDR R0,[%x0] | LDR R0,[%y1] ; EOR R1,R0,R0 | LDR R1,[%y1] ; ADD R1,R1,#1 | MOV R2,#2 ; STR R1,[%y0] | STR R2,[%y1] ; | LDR R3,[%y1] ; | EOR R4,R3,R3 ; | MOV R5,#1 ; | STR R5,[R4,%x1] ; Observed 0:R0=0; 1:R0=1; 1:R1=0; 1:R3=2; y=2; and 0:R0=1; 1:R0=0; 1:R1=1; 1:R3=2; y=2; and 0:R0=1; 1:R0=1; 1:R1=1; 1:R3=2; y=2;
