Executions for behaviour:
"0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 1:R4=2 ; z=2"
"0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 1:R4=2 ; z=2"
"0:R0=1 ; 1:R0=1 ; 1:R1=1 ; 1:R4=2 ; z=2"
ARM LB+data+pos-data-wsi-rfi-ctrl-po "DpDatadW Rfe PosRR DpDatadW Wsi Rfi DpCtrldW PodWW Rfe" Cycle=Rfi DpCtrldW PodWW Rfe DpDatadW Rfe PosRR DpDatadW Wsi Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe PosRR DpDatadW Wsi Rfi DpCtrldW PodWW Rfe { %x0=x; %y0=y; %y1=y; %z1=z; %a1=a; %x1=x; } P0 | P1 ; LDR R0,[%x0] | LDR R0,[%y1] ; EOR R1,R0,R0 | LDR R1,[%y1] ; ADD R1,R1,#1 | EOR R2,R1,R1 ; STR R1,[%y0] | ADD R2,R2,#1 ; | STR R2,[%z1] ; | MOV R3,#2 ; | STR R3,[%z1] ; | LDR R4,[%z1] ; | CMP R4,R4 ; | BNE LC00 ; | LC00: ; | MOV R5,#1 ; | STR R5,[%a1] ; | MOV R6,#1 ; | STR R6,[%x1] ; Observed 0:R0=0; 1:R0=1; 1:R1=0; 1:R4=2; z=2; and 0:R0=1; 1:R0=1; 1:R1=0; 1:R4=2; z=2; and 0:R0=1; 1:R0=1; 1:R1=1; 1:R4=2; z=2;
